Gunite tomorrow, high of 111*
NinjaWorf
31
Mesa, AZ
Having gunite done tomorrow and the high temp is going to be like 111* here in PHX tomorrow and I'm the 2nd job so probably 11-12ish start time...I'm a little nervous. I'll be on a strict watering schedule for curing.
Psycho1122
90
Mesa, AZ
Keeping the new shell watered after will be the chore. As stated above, when the plaster gets done will be key. Job should take 3-4 hours and if temps and direct sun are the issue, inquire how they will "tent" your pool to slow down curing time.
Good Luck! Cheers!
Reactions: NinjaWorf
NinjaWorf
31
Mesa, AZ
Thanks, for some reason I was thinking gunite was more sensitive vs the plaster stage. That's probably in a few weeks I'm sure temps will be the same or higher :oops:
jimmythegreek
In The Industry
Aug 10, 2017
2,834
Morris Cnty NJ
It's fine they will adjust the mix and you will be on water duty. I've seen a hose bib timer setup on one of those light spray sprinklers do the watering automatically. Plaster is another story as said
