Green water help
Bdgreen
2
Oklahoma
Problem: green water after 3 days of rain and vacation.
FC:
TC:
pH: 6.2
TA:
CH:
CYA:
Alk:80
My pool:
Pool chemicals: baquacil 1 quart
My pump & filter: cartridge
Other info: used 2 lbs of shock
I am having trouble getting the water to clear up. Am I not adding enough shock. Water is only 6 weeks old. This happened while I was on a 3 day vacation and had 3 days of rain.
Leebo
Admin
9,945
Eastern Ohio
First and foremost......WELCOME TO TFP!!!
Onto the question. You mentioned you’ve added “two pounds of shock.” Can you expand on this comment? What we’re the active ingredients in this Shock??
YippeeSkippy
14,445
Evans, Georgia
Oxi non-chlorine shock a product one normally uses in a Bacqua pool? I'm unfamiliar with its use like this.....?
Can you do us a favor and fill out a signature line (under "Settings") and tell us about your pool, its equipment, chemicals, testing, etc? That really goes a long way to help us answer you better. Thanks :)
Maddie
