Like most here, I opened late to a green swamp. Worse than I have ever seen in the 6 years we've had the pool. I'll spare you the pictures.
Brought PH down to within levels. I have my pool and test results linked to my profile, so you should be able to see what I've done. I threw 3 pucks in because I have 0 CYA, if I'm remembering right it raises that a tiny bit.
Added 4 gals 10% bleach, water turned much lighter, milky green within 30 minutes. Lighter even more during my 1 hour test.
I'm not seeing any change in between the FC and CC numbers. Should I? I feel like I'm doing something wrong if I don't. I did run the net around the bottom of the pool and have very few leaves or debris.
I also should add that I close my power cover between chem additions and tests. So it isn't left open for the sun to eat my chemicals. I'd like to know if this helps or hurts.
Oh also you should know that I'm a second guesser when it comes to color changes in the test tube. I spend way too much time trying to dissect if there was a change, how much, etc.
Thank you in advance to all the experts!
