Green pool again
Thomas Vegas
87
Las Vegas
Hello TFP community.
2 month ago my water pool was green, I did the SLAM process with success (OCLT passed)
I noticed green on the wall came back more often, in less days, and more often I need to add muratic to balance my ph
My water began to turn slowly green, even with daily maintenance and chemical checking. After few days, I figured it out the spider gasket was damaged again, so probably bad quality.
So this time I ordered the full "key, cover and handle assembly" for my filter. It took the weekend to come. But the water during this time turned completely green.
So I began the SLAM process. It was Monday. And since then no improvement at all...
Desperate, and believing my filter is still wrong, I called a pool guy yestesday, who have good reputation on the neighborhood. He checked the filter and put DE on the skimmer to see if goes out through the buses. Nothing goes out. So apparently it's good, the filter is doing his job, with the DE, it raised the pressure. We backwashed it. And he put an algeacide on it (call Algatec).
I continued the SLAM process.
The next day, today, still no improvement.
So should I be more patient?
Thank you for your help.
Here my PoolMath link PoolMath Logs
The last CYA test I see in your logs was 30 ppm. That is OK for the SLAM Process, but not for normal maintenance. You need at least 50 ppm CYA in your water here.
The algaecide has all ready been consumed by the chlorine. A waste of money.
Maintain your FC at 12 ppm every two hours or so.
Ok, one more pool guy useless, I was worry about that...
Ok understood for the CYA, I believe the less the better and 30 was enough
So you advice me to just be patient? no to try to investigate on the filter?
Thank you for your advises
Filter does not solve or create algae. It is needed to filter out the dead algae.
Why do you think you have an issue with the filter?
Less CYA is good to a point, but with our UV impact, I suspect your FC is dropping rapidly mid day.
And looking through your logs, you spent all of June, July, and part of August at a very low FC level. Once you finish the SLAM, make sure you are keeping your FC at the correct levels (see my signature if you need) to keep the algae away for good.
Looking at your logs, I see you testing and adjusting pH during your SLAM. Leave it alone. Your pH readings are not accurate with the elevated chlorine levels.
If your FC happens to drop below 10, perhaps overnight, then you can test your pH. Otherwise, it's not accurate.
Thomas, algae is a CHEMISTRY problem. Filtering is a MECHANICAL problem. If you have algae your chemistry is off- usually either too low FC or too high CYA.
BUT.....you live in the very hot west.... more sun and UV than most of us... so you actually need a skosh more CYA to protect your FC than most of us East of you. And when you have higher CYA you need to continue to follow the FC/CYA chart for guidance on how high your FC should be.
See---> FC/CYA Levels <----- See
I hope this explains it and helps clear up any confusion.
Maddie
Usually, I do my test at the end of the day and just after put chlorine on it, according my tests
I am guessing the chlorine get consumed by the sun during the day, in the average I put 48 oz every day.
I'm guessing that is what happened, but the minimum is still the minimum and will allow algae to grow if the FC dips below there. For a CYA of 30, the minimum is 2, target is 4-6. I would make sure and bring it up to at least 6 when you add on a daily basis, but there is no harm in bringing it up to 7 or 8 if you are seeing a lot of burn off during the day.
An FC of 0.4 or 0.0 is too too low at any point in time. That's where your algae is coming from.
Either you aren't adding enough chlorine to get your levels up to where they need to be, or it's getting burned off too quickly. If it's burning off that fast, you need to raise the CYA or dose multiple times a day. But first, finish the SLAM, and then figure out if your chlorine perhaps isn't as strong as you think, or you were targeting too low, or if it's being consumed that quickly.
Also, what strength of liquid chlorine are you using. 48oz is not a lot.
Never mind - Mknauss beat me to it.
Maddie
Yes but the filter not removing the dead algae (if the filter is an issue) will keep my pool green, is it not? But reading your answer, the filter doesn't seem to be the issue here...
So I will continue my SLAM, and will see. But no seeing any improvement, doesn't help to believe I was in the good way... I will be more patient.
You right about the CYA because I felt I put a lot of chlorine ever day (average 48oz) and still doesn't seem enough?
Ok I have a 30k gallons pool, but no pool party (because the covid), no kid peeing on the pool, no dog... just 2 peoples (and a lot of UV, ok).
OK understood.
For the CYA, I believe the lower the better... 50 seems to be the correct amount.
Algae that dies will land on the floor and look like silt or dirt that floofs away if you get near it. A S-L-O-W vac to waste will help get it OUT of there.
Brushing daily keeps it stirred up in circulation so that the filter will capture it, as well as the brushing disrupting any biofilm which can be hiding algae below.
Maddie
