GPM keeps dropping on IntelliflowXF VSF Pump
imranmoin
7
San Jose / California
I recently installed a brand new IntelliflowXF VSF Pump. However, my GPM (Gallons per minute) keeps dropping for a given RPM (Speed). Eg. I set this pump at 2500 RPM and had over 40 GPM yesterday, Today, it has dropped below 10 GPM. Is this normal? Note that I have a relatively clean filter (Hayward DE4820). Any points on how I can maintain my GPM would be appreciated.
cowboycasey
8,648
Southern OK
CircuPool SJ-40
Is the RPM the same at 2500? If so the GPM could be going down because the filter is working.. DE will clean the most out of water and slow the water flow (GPM) down..
If you change the pump over to GPM instead of RPM it will try to keep the GPM.. I am afraid the RPM will max out and not be able to keep the GPM...
imranmoin
7
Hi @cowboycasey, thanks for your feedback. I did not realize that GPM going down because of clean water is expected. I thought that the pump and/or filter is not working properly. Another thing to note here is that PSI pressure went up to 25. It was around 10 yesterday. Is this expected as well?
mknauss
44,310
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
A rise in filter pressure indicates you have an issue with your water chemistry. Can you post a full set of test results?
cowboycasey
8,648
Southern OK
CircuPool SJ-40
you should clean your filter at 25% pressure rise.. If your filter was at 10 PSI your should be backwashing about 12 to 15 PSI... Sounds like you have something growing.. what are your test results :)
