Glass Tile Spa
calculus
10
Florida
Hi, I'm renovating my pool and I'm thinking of putting Glass Tile on the Spa. I live in the Jacksonville, FL area. I heard that Glass Tiles tend to crack with time. I have been reading that the Glass Tiles don't crack as long as they are frost proof. I also read that there is a difference between frost proof and frost resistant.
What do you guys think about Glass Tiles?
ajw22
20,352
Northern NJ
Expensive.
You need to maintain all the grout lines to repair cracks and erosion and prevent water from getting behind the tiles and lessening them.
Looks great.
phonedave
741
Montville NJ
If you want to see some amazing glass tile work, look up Jimmy Reed at Rock Solid Tile. That is all he does. Glass mosaic tile installs in pools, spas, and water features. He does a LOT of high end stuff and is a stickler for details. I forget exactly what product he uses, but I know it is Laticrete products and Bisazza tiles. If he trusts it on the 6 and 7 figure installs he does, it would be good enough for me.
He talks about what he uses here
at about 3:00 in
ajw22
20,352
Northern NJ
Tiles cracking is different then tiles lossening from water getting behind the tiles and eroding the thinset. Using quality products like Lacrite help.
TLT
23
los ángeles
[B]calculus[/B] I have the exact same situation as you and just asked the same question yesterday on this forum. Maybe the answer is slightly different if you are in a warm climate. But I don't understand why glass tiles would loosen from water getting behind it anymore than porcelain.
ajw22
20,352
Northern NJ
Nothing different about glass tiles loosening. Issue is the amount of grout lines in a tiled spa and needing to prevent water erosion. Especially if 1”X1” tiles are used.
TLT
23
los ángeles
Ohhh, so the less grout line the better. But glass tiles tend to be small mosaic so they the turn corners and sparkle.
spd500
547
Houston, TX
When I was checking into glass tiles I was told by the supplier that the difference in glass tiles is the heat treating process. If they are properly heat treated they are not supposed to crack according to him. Here in Houston, he used the example of the tile being hot from the sun and cool water being splashed on it creating cracks, if you are in an area that freezes you have other conditions that can also crack tile.
Reactions: TLT
