A few questions as I just got in my Glacier GPC25 Cooler in, but not going to be plumbed until Monday 8/16/21.
1. The fan blades came slightly angled/tilted, not 100% horizontally flat. Is that how they should be, slightly tilted?
2. I have a Pentair Superflow VST variable speed pump. I normally run at 1400 rpm at night from 9:00pm to 8:00am (2700 rpm from 8:00am to 2:00 pm for my Rebel cleaner, then down to 2000 from 2:00 to 9:00pm-my Pentair IC 40 SWG requires over 1900 rpm). What speeds do you run at or suggest for the Glacier? I read in the manual about running it at "high speed for variable speed pumps" but that could mean almost anything over 1000rpm I guess.
3. Did you bolt down your Glacier? Mine weighs 125 lbs (58" high and 34" wide) and sits on a 30"x30" concrete pad I made for it. Am wondering if it might topple over in a 50-60 mph desert wind we sometimes get here. Thoughts?
4. I assume its OK to leave my auto pool cover on a night while I run the Glacier?
Thanks for any help!
