Getting picky with water clarity
suzypats
Active member
Nov 13, 2020
41
New Jersey
Hayward Aqua Rite (T-9)
Im getting picky here but I had to drain and refill my pool for a liner issue last week and when i refilled the water looked pristine. Now, after having it for a few days the water doesn’t sparkle the way it dis before. I adjusted my salt, cya and added chlorine to boost while my salt system got back on board. I try to follow the trouble free pool method and don’t shock my SWG pool. I keep my chlorine around 7.5, cya is 50ish and PH is 7.4-7.5ish. How do I get that sparkle back?
suzypats
Active member
Nov 13, 2020
41
New Jersey
FC-7
PH brought down to 7.2 from 7.6
Total alkalinity 60
CYA 55
Salt 2900
Hayward cartridge cleaned today for first time. Running pump around 13 hours a day 7am - 8pm
mknauss
51,248
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Maintain what you have as it should sparkle like before. You do not report CH but that would only be an issue if it was high.
suzypats
Active member
Nov 13, 2020
41
New Jersey
CH has never been high but i will double check. Here is a pic of the difference. maybe i am being too picky? Left is today, right was from right after refill. 18635DE0-CBD2-41F2-9FFD-3F028FF10687.jpeg
mknauss
51,248
Laughlin, NV
Fiberglass
OK -- dull water typically means high pH. But you are not testing that.
I assume you have your SWCG at 100%. If so, at 13 hours per day, you are creating 3.3ppm FC per day. That is right at average.
suzypats
Active member
Nov 13, 2020
41
New Jersey
Ive been running it at 70-80%. 13 hours a day. Should I be running higher?
mknauss
51,248
Laughlin, NV
Fiberglass
At 70% it is 2.3 ppm per day. That is pretty low for this time of year. Test your FC daily for awhile (preferably in the morning before your SWCG starts) to be sure you are staying at target FC for your CYA.
