General SWG questions
bobfloyd
Active member
Oct 16, 2014
38
Australia
#1
Answers would no doubt be in the many other posts but I'm not having much luck finding exactly what I want to know...
Some questions...
1. The chlorinator output control knob - is this just a variable resistor? Cranking this to max lowers the resistance thus increasing the current through the chlorinator plates?
2. The chlorinator output meter - this is nothing more than just a calibrated ammeter?
3. If the chlorinator plates are old and the coating is worn down, thus the plates are not producing chlorine efficiently anymore, this won't have an impact on the current flow, thus, the output meter could still read 100% even though the chlorine output is not good?
4. There are 3 wires going to the cell, black, red, white. I presume the white is connected to a probe that checks for a closed circuit (I.e. Back to red or black) to ensure there is water in the cell housing?
5. The coating on the plates isn't a catalyst per se, it's actually slowly consumed by the chlorination process?
6. Without the coating, the titanium plates would still produce chlorine, but not as much? Somehow the coating stimulates more chlorine production?
Cheers,
Scott.
ajw22
3,269
Northern NJ
#2
What make and model SWG are you asking about?
Please put details of your pool in your signature. It gives all of us context to properly answer your questions.
Brad_C
64
Perth, Western Australia
#4
In a manner of speaking, but not directly. ie it's not a rheostat, it just drives the electronics.
Kinda, sorta. In general Cl output is proportional to the average cell current, but sometimes there are fudge factors applied by the electronics to manage things like duty cycle so you may not be seeing a direct coulomb count.
No. As the catalytic coatings are degraded the resistance of the cell to the water increases, so current flow and consequential Chlorine output falls. Same effect as the water gets colder. Most chlorinators have the ability to increase the voltage across the cell to compensate so you don't really start to notice until it's "mostly dead" and the chlorinator runs out of ergs.
Hard to say. Some do, some use a center tapped cell, some have electronics in the cell.
No, it's a catalyst. Like any catalyst it is subject to degradation and poisoning. This is the ultimate limiter of cell life.
I suppose in tiny amounts it's possible. My experience is pure titanium seems to tend more to plain electrolysis of the water so you get oxygen rather than Chlorine.
Jan 31, 2019
5
Australia
#5
I just replaced my SWG on Friday and opened up both to see what makes them tick.
Not directly. The standard SWG circuit has the transformer secondary go through pairs of SCRs which are driven by a control board. The SCR output goes to the cell. The control knob adjusts the control algorithm on the control board which then adjusts the on-time of the SCRs. Hence varying the output power seems to just control how much of the AC cycle goes through the cell. It's essentially a glorified electronic dimmer.
Yes, it measures cell current. My previous SWG measured electronically across a shunt and displayed the output on a LED bargraph. My new one has an analogue meter wired across the shunt.
I guess that depends on the chemistry of it all. But I imagine if the output meter reads 100%, then there is full current flow and the electrolysis is making _something_.
Yes, the white wire measures water flow/presence.
bobfloyd
Active member
Oct 16, 2014
38
Australia
#6
Thanks guys.
Bgpbucko - so the output knob is controlling the scr gate voltage? My understanding of why an SCR is used in the first place is so that there is a means of controlling at what point the anode/cathode current may pass. So we're basically controlling the duty cycle? The chlorinator plates I presume receive a steady voltage but this is pulsed via the scr's ? The output meter is somehow taking an average current flow? Can you clarify what the shunt does?
Any idea guys how the reverse function works? What times when the reversing occurs (e.g. I can select every 4 hours or 8 hours).
I presume given there are 4 Scr's in the chlorinator, 2 of them are working away for say 8 hours while the other 2 sit there cold and patiently waiting for their turn?
Scott.
Brad_C
64
#7
It honestly depends on the chlorinator. Mine has 2 triacs rather than scrs( effectively 4 scrs in back to back pairs) but the implementation is really device dependent as is the gate triggering logic. Reversal is just that though, it just reverses the effective polarity of the cell.
Jan 31, 2019
5
Australia
#8
The power that goes through the cell is actually rectified AC, straight off the transformer at usually 9V. Because of this, it's a rectified half sine wave at 50 (or 60)Hz. The SCRs are just switched diodes, turned on at varying parts of the sine wave cycle. If it turns on in the early part of the cycle, more energy goes through the cell. Whereas if it's switched on in the latter part of the cycle, less energy is sent through.
Two SCRs are used as generally the transformer is center tapped. One tap uses energy on one part of the AC cycle, the other tap has the inverse polarity and is used for the other half of the cycle. This also means that the chlorinator cell gets a chopped half sine wave through it, not steady DC voltage.
The output meter is just a regular old ammeter configuration - a shunt resistor in series with the load and a meter across the shunt which actually measures the voltage. The distance the pointer moves is the average current of the half-ac cycle, with the AC cycles damped by the spring.
As Brad_C says, the extra pair of SCRs is used to reverse the polarity. Essentially, the are wired in parallel but reverse with the other pair and switched during the reverse cycle.
