Gallons size per pool: Use what Intex manufacture say on Box? Or use Pool calculation based on measuring pool with equation?
arosas
8
Dresden, TN
Which to use?? Using the Pool Calculator I have been using the Gallon size that Intex/Coleman printed on box for our 18ftx48 pool. But when I used the equation to figure gallon size. There seems to be a 500gallon difference. I have been using the Pool Calculator to log & follow what chemicals to use to balance pool. Having a wee-little issue getting pH and TA to stay at target/goal. But I think it may be because I have put in the manufacturer figures for Gallons . The goal/target are based on those figures? Which should I use? And maybe I did the math wrong. Pool box say 6,092 gallon at 90% full. ( as far as I understand) My calculation- 6,660gallons
jblizzle
43,260
Have you been hitting your targets when adding chemicals? If you are over/ under shooting, then adjust the volume. It is not critically important.
Note that pH is going to always be drifting. Rare to get it locked in.
arosas
8
Dresden, TN
Adjusting slowly to hit targets. I have Well Water. pH has actually been pretty stable. It’s my TA that actually keeps swinging. (Placed new order for Taylor CYA reagent , waiting for it to be shipped. ) Thats why I was wondering about the volume/gallons. Thank You for replying🤗 I am going to try adjusting volume and see how that goes.
