fuse keeps blowing on Hayward swim pure salt water panel.
chris4150
Let us know how it goes.
So after installing new rectifiers, the panel is working properly. However, the settings aren't correct. It does not display the cell as being ar-15. Nor does the desired chlorine output coincide with the dial setting. Not sure what each reading means. Pics
JamesW
30,662
The circuit board that you have is not Hayward.
It is a generic aftermarket board.
It might not have a cell size setting.
It looks like it is set to metric.
Go to the 34 and move the switch from auto to superchlorinate and back to auto to switch to Fahrenheit.
JamesW
30,662
The Red wires go on the + terminals, which are the terminals that are turned relative to the other three and sometimes are marked by a cut corner..
The black wires go on the opposite terminals, which are the (-) terminal of the DC.
The yellow or orange are the AC from the transformer.
What exact rectifiers did you get?
Rectifiers aquarite.pngBridge rectifier 333.pngInkedRectifiers aquarite_LI.jpg
chris4150
Here are the pics
JamesW
30,662
The display board is probably going bad.
The dial can become corroded.
You can try some electronics cleaner on the dial or replace the display board.
What cell do you have?
How old is the cell?
What is the actual salinity?
JamesW
30,662
I would spray down the display board with electronics cleaner, especially the dial controller and let it dry before reinstalling it.
I would get a K-1766 salt test kit to check the salinity.
chris4150
ordered a new display board. should be here today. If anything, I can reinstall the previous main board now that we determined that it was not the issue. The previous board is an OEM board. Ill had the new display board to it.
Reactions: JamesW
C0d3Sp4c3
214
Inland Empire, CA
Hayward Aqua Rite (T-15)
I cannot help with a non-OEM Hayward pcb. I can only assume your salt level is way too low for the cell to produce chlorine or perhaps the cell is dying. Hence, the fault condition. How are you measuring your salinity? But anyway, I was about to suggest to re-install the old board for comparison. All you need is a couple of female Spade connectors for the AC power.
Should you decide to use the old board, run the diagnostic 10 secs after the "Generating" LED comes on and post all the readings. You have exactly 50 seconds before the controller error out if it detects any fault condition.
chris4150
what were the steps to run the diagnostics?
chris4150
I would image its not reading any salt as I have not added any in over a month, just chlorine tabs.
JamesW
30,662
Just push the little black button and record all of the readings.
Salt does not go away unless you lose water other than evaporation and then refill with fresh water.
So, the salinity should be about the same as before unless you have lost a lot of water and refilled.
You should get a K-1766 salt test kit and/or a good salinity meter to verify the actual salinity.
