Frustrated!
Jdenise32
1
Oklahoma City, Ok
This is our 3rd summer with the pool. 1st summer the pool was open and clear when we bought the house. 2nd summer was a play it by ear way of trying everything but it seemed to go ok. So here we are the third summer. The pool in an in-ground/vinyl lined/chlorine/sand filtered pool.
We have started opening the pool about a month ago and have still not been able to get it clear. All of the test reults from the pool store are basically normal except the TA is realy high at 200, but the PH is good and chlorine levels are good. No metals are detected.
However! Our pool is still green (a pretty light green and cloudy). And our white plastic steps keep turning orange when we put in chlorine (the only time that goes away is when we let the chlorine go down).
Jimrahbe
11,317
Bedford, TX
Denise,
Welcome to TFP... A Great resource for all green pool owners. :snorkle:
You say your chlorine levels are good, but you really can't tell unless you know what your CYA level is...
I suspect that you have been using 3" tablets to chlorinate your pool. If so, by now your CYA may be so high that it is almost impossible to add enough chlorine to kill off the green algae.
The TFP process is based upon you testing your own pool water and then adding only what is needed to return your pool to a clear and sanitized pool you want it to be.. No more going to the Pool $tore for more magic potions, no more "shocking" your pool on weekly basis, no more chemical smells, and best of all, no more problems...
Most pool owners use only Liquid Chlorine or plain bleach and Muriatic Acid to keep their pools in perfect condition.
Check out these three links and let us know if you are interested our the TFP way...
https://www.troublefreepool.com/content/122-what-is-tfpc-bbb
https://www.troublefreepool.com/content/125-slam-shock-level-and-maintain-shockingl
https://www.troublefreepool.com/content/128-chlorine-cya-chart-slam-shock
Thanks for posting,
Paul & Crystal
539
Oklahoma City, OK
Hello JDenise,
That does sound frustrating, but you've landed in the right place if you want to control your own water.
First off, you must have your own test kit and test your own water. TFTestkits.net has the TF100 which is what most people use. Taylor also makes a test kit that is good. If you have your own test kit, the folks here can help you get your water cleaned up for good.
While waiting for your kit to arrive, read about the TFP method in the Pool School area.
How big is your pool?
Welcome to TFP!
Crystal
Patrick_B
14,999
Midland TX
Hi Denise, and Welcome!
We can get you out of the rut of guessing on a fix, and not understanding why things aren't working. If you look around the forum, you'll find tons of people who once thought it was hard, but a lot of them are here giving advice now. It's really easy after you learn just a few basics. Hope to see you around, and getting this going your way.
Thread starter Other Threads of Interest Forum Replies Date
M Testing and Balancing Your Water 23
