We woke up to an empty pool this morning. Upon inspection I found a broken coupling at the waterfalls pump. The freeze protection WAS on but both intake baskets were full of leaves (the freezing temp came with some massive winds). It appears that the pumps kept drawing water in and spewing it out the top until the pool was empty.
I’m assuming that my best course of action is to get this coupling fixed, refill the pool and get it running again. Would there be any reason to just drain the water that’s left and leave it empty for the winter? I think that might cause problems with plaster cracks and such, yes?
Is there anything I should take advantage of the moment to do? For example our pool lights haven’t been working. I’m trying to source new ones this AM so I can replace them while it’s empty. Should I do anything about filling in these divots on the bottom? (Wind blew some patio furniture in.)
Any advise to avoid this in the future or additional thoughts on why it might have happened?
Thanks in advance!
Thanks in advance!
