Found a bucket of DiChlor
yankees177
Active member
Aug 23, 2016
35
Ballston Lake, NY
Back 3 years ago when my pool was put in a got a whole bunch of chemicals from my builder. I gave the tabs to my friend but just found a 25lb bucket of DiChlor in there. Was thinking about selling it since I use liquid chlorine only but I could use it to boost my CYA if needed, correct? If so where is the calculation for that? I don't see it on pool math, I only see DiChlor for adding chlorine to pool.
zea3
12,437
Houston, Texas
Go to PoolMath, fill in the size of your pool, then go down to the bottom where it has the "effect of adding chemicals section" You can calculate how X ounces of dichlor will affect pool chemistry.
Reactions: yankees177
yankees177
Active member
Aug 23, 2016
35
Ballston Lake, NY
Thanks this is what I was looking for. After some evap and water add I'm down a bit on CYA (approx 35) and I need to add chlorine so about a lb of DiChlor will get me to where I want to be all around. Thanks!
yankees177
Active member
Aug 23, 2016
35
Ballston Lake, NY
Hey so quick question. There is a cup in the DiChlor but those OZ are fluid OZ correct, not weight OZ. I struggle to figure out how much stuff weighs without a scale.
