I’m seeing some good results with folks using XPS extruded foam panels or the anti fatigue mats. I want to use the xps. I have a beaded liner. What’s the best way to deal with the recommended 3” thickness that sand gives?
Hi and welcome to TFP! The first thing you do it measure how thick the panels are. Once you have the measurement subtract that from 3" so you know how deep the sand needs to be. The sand will go UNDER the panels. I would also get and use foam cove pieces. They will go on top of the panels.
