Foam or pad?
ta2dwonderwoman
523
fall river ks
We are getting ready to put a new liner on our old frame This week and I am hoping to do a bit of an upgrade to the bottom... I have Searched the the forum and got completely overwhelmed trying to find an answer so I am hoping a few people with some experience can help here...
I am considering gorilla pad from Amazon , but have also read a lot about foam, so I'm wondering if some folks can give me an idea of what they preferred and what worked better for them if they've tried both. I leave my pool up year round, So I definitely want to use whichever option is going to last as long as my liner will last. Thank you in advance for your opinions, they mean a lot to me :)
kimkats
42,178
Tallahassee, FL
The Gorilla pad is not really a pad. It is thick plastic sheeting. It's purpose is to keep grass and such from growing through the pool bottom. The house foam adds comfort to your feet as it is soft. It will also "take" some of your water depth due to it height.
I am not sure if that helps or not. I will tell you I have only have sand under mine. I would like to have the house foam but it was not in the budget so sand it is!
Kim:kim:
jimmythegreek
In The Industry
Aug 10, 2017
1,391
Morris Cnty NJ
foam or sand, the gorilla pad is not really a pad as Kim said. if you use foam you have to be careful and make nice cuts and tape together you dont want voids
aboykin2269
323
Pittsboro NC
We decided to do both. I did a sand base (wet and tamped), then put down the gorilla pas (for weeds and nut grass), then we put down 1/2" foam for a smooth bottom. It really came out great.
106221
106222
Reactions: sammckin
ta2dwonderwoman
523
fall river ks
Thank you everybody! In the end I went with gorilla pad due to budget constraints and knowing that I have to do it all myself because my husband is out of the loop at the moment Due to a pretty major shoulder surgery he had recently. We previously had sand and weed barrier down so the gorilla pad will be an upgrade from the weed barrier.
Reactions: thefloatqueen
ta2dwonderwoman
523
fall river ks
OH NO! I hope the surgery went well and he is pain free already!!
Kim:kim:
Had a reverse shoulder replacement with a relocation of his pectoral muscle so that it can Do the work of a deltoid... I also replaced the top half of his humorous... It was a very radical and aggressive procedure that was necessary due to the complexities of his shoulder... he is right at 2 months out from surgery right now and doing very well. It will probably be right out a year before we start to get an idea of how successful it is going to be...
ta2dwonderwoman
523
fall river ks
And now that we've gotten part of it taken down I remember that it's not weed barrier under the pool it is actually a tarp... So we will leave that in place and Put gorilla pad over it
kimkats
42,178
Tallahassee, FL
:shock: on the shoulder rebuild! Glad to hear it might be doing what it needs to do.
Good move leaving the tarp. It did it's job so let it keep on working!
Kim:kim:
ta2dwonderwoman
523
fall river ks
Kim:kim:
I took the Frame down today and am happily surprised that there's not a lot of rust... There is a little here and there but not much to write home about. I'm going to sit down tomorrow and clean everything thoroughly and let it dry in the Sun , Then I will hit it with Something to remove the rust and then a couple of light coats of rustoleum paint , just on those spots... My biggest fear was that I was going to get pulled apart and find so much rest that I wouldn't be able to use it to put the new pool back up...whew!
kimkats
42,178
Tallahassee, FL
This is what Lee told me:
"Make sure they’re not taken HDR photos as these are (and have been) always blocked by the server due to their size. They’re just to large. "
I had forgotten about this tidbit! Changing that setting should fix this problem!
ta2dwonderwoman
523
fall river ks
I'm not sure I know what an HDR photo is, I am just trying to upload photos from my phone as I always have with no problems. :(
