New pool - was going off the spec chart for the plans that shows 54gpm at 1,500 RPM for the Pentair Intelliflow VS. Noticed my Jandy JXI heater says 'check flow' when I activate the bypass valve and send water through the heater.
I have to increase the speed to about 2,000 rpm to get the Heater to have sufficient flow (the manual says 30 gpm minimum)
The interesting thing is at 1,000 rpms - the Intellichlor says it has sufficient flow - and that manual says 25 gpm +/- 5.
My main and returns are 3" (reduced to 2.5 inch for all the valves at the equipment)
The heater is 2" in
Maybe the heater is just more restrictive to flow? I can 'hear' the water in the heater if that makes sense
Really just trying to figure out a good amount of run time for the pool on a daily basis.
The heater is 2" in
