Trying to figure out the next step.
First a little history… Saturday we got trounced with 5” of rain in a very short period of time. It overwhelmed our gutters and drainage. It also overcame the pool deck grading and dumped a bunch of mud/dirt into the pool. It’s actually more of a light gray fine dirt of some kind. The stuff that’s on the pool deck actually feels a little powdery – a very fine dirt. I woke up Sunday to a solid gray pool with zero visibility. The filter pressure gauge was pegged all the way over (I think that’s around 50psi). I shut it down and attempted to let it settle. Ironically, the pool chemistry was still perfect. Apparently, this dirt brought in practically no organics with it. The filters didn’t really look that bad – until I started rinsing them. Wow, they were really loaded with dirt.
It looked a little better Monday (after 24 hours of calm settling time). So, I decided to try to filter this stuff out. I expected them to clog almost immediately. However, they never did. The pressure never built up. I guess the larger dirt particles that the filters were capturing before did actually settle to the bottom on their own. So, I think that part of my strategy was good. However, the pool wasn’t clearing. On Thursday I was considering a floc treatment since it has been several days with little improvement. So, I pulled the filters. This time there was very little dirt that was rinsing out. This is consistent with the pressure reading. So, obviously, the remaining stuff is too small to be captured by the filter. Again, the chlorine’s been holding this whole time. I did add what would normally be expected. So, the chemistry is stable. We aren’t dealing with algae. We are dealing with some kind of fine powdery dirt.
Thursday evening I decided to try a floc treatment. Based on the descriptions I’ve seen, it looked like too severe of a case for a clarifier. Besides, I have great options for vacuuming to waste. Even though we have cartridges, we have a waste diverter valve. But, even better, we have a siphon option as we have a hillside off the back of the pool. The siphon allows me to go non-stop even taking the water level well below the skimmers. This works great for opening as you don’t have to stop for any basket cleanouts. So, I figured I’m good in that department.
Thursday night and today (Friday) has been perfect weather for this. ZERO winds. Super calm. Only problem, the floc didn’t seem to capture any particles. The pool still looks the same. It’s been 24 hours now.
So, where do I go from here. I’m not expecting the pool to look any better tomorrow morning (36 hours after floc).
Thanks.
- Should I give it longer? And, how much longer? I’ve read 24-48 hours.
- Should I “refloc” and start the pumps for a couple hours and try again? I’m concerned that this dirt may be resistant to sticking to the flock.
- Should I put in a very old set of filters that I don’t really care about (I almost threw them out) and let it run with those and see what happens? I was planning on using these after the floc treatment anyway.
- Maybe above with a clarifier.
- Any other suggestions?
Thanks.
