Just moved into an older home which has a pool. Noticed the float valve was missing from the skimmer (standard 2 holes: main drain and pump suction), so I ordered one. This is the first pool I've had which has a spa, but the valve arrangement looks pretty simple: supply side can be from the pool or the spa drain, and likewise the output can be adjusted between the pool and the spa jets.
Question: The float valve arrived today, so:
Thoughts?
- I adjusted the control flap underneath (usually I leave it 50% open so I get some pull from the main drain),
- Put it in the skimmer, and
- The pump noise level immediately elevated.
Thoughts?
