Flex pipe repair
Goldenzrule
6
Newtown, CT
Hi Guys. I have to repair a flex pipe that inadvertently took a rebar right to the kisser. I dug it out, its right by the pool equipment. I have some schedule 40 1 1/2" couplings. I was wondering if these are the correctly couplings to use. The pipe also appears to be 1 1/2". I have never repaired flexible pipe, so wanted to check before tackling it. Once the repair is done, it will not be easy to get to later on. I am guessing cut the pipe cleanly, clean off any shavings left, prime the pipe and inside of coupling, and glue like standard PVC? If I am way off, please let me know. Thanks.
mas985
14,799
Pleasanton, CA
There are many types of flex pipe but if it has the smooth exterior and is PVC, then you should be able to glue a coupler on it. The outer diameter of ridged PVC is 1.9" so you might check that dimension.
