fixed low salt error how can i connect flow sensor
Hydrosan
2
Longview Washington
Hello I just found this site and fixed my intex low salt problem by rewiring unit. don't mind running unit on a timer , but would like to rewire the flow sensor , can it be jumped into the chlorine cell line to let the unit only produce chlorine when the water flows ?
Hydrosan
2
Longview Washington
Hello dgramenz I hope this helps you with your low salt error problem. I found the main fix in the forum on this very website here is the link to the post. ECO8110 SWG code 91 bypass . Good luck .
We have an intex 16" x 32' ultra frame pool running an aftermarket pump intex sand filter and a Tropi-Cal heat pump.
mas985
14,012
Pleasanton, CA
You have bypassed all of the safety provisions so the flow switch will not work. This is a really bad idea as SWGs can explode if there is no water flow through them while energized.
