Fixable -- ball valves cannot close completely?
baip
Active member
Aug 7, 2019
33
Sunderland, MA
The two ball valves connected to two skimmers, circled in red below, become very hard to turn and no longer close completely. As a result, when I try to lower the water level, as soon as it drops below the skimmer, the pump would lose prime. Is it possible to fix these issues with ball valves and, in general, what's the recommended move for this situation?
baip
Active member
Aug 7, 2019
33
Sunderland, MA
They all do this eventually. Replace them all with Jandy Never-Lubes
2 x 2-way Jandy valves for the two worn skimmer valves? Or is there a way to replace both the two skimmer valves and the main drain valve with a single Jandy valve? I saw the most is 3-way. And do Jandy valves last that much longer to be cost effective?
YippeeSkippy
16,677
Evans, Georgia
And by the way, what's the purpose of the right-most pipe (the one without a ball valve) that's split from the return line?
Got any water features? That would be my guess, or a Pressure Side cleaner. It seems like it ought to have a valve on the line to meeeee....but whatda I know??
Maddie :flower:
baip
Active member
Aug 7, 2019
33
Sunderland, MA
No water features I can see.. And there is nothing that seems to connect to a pressure side cleaner. Essentially this no-valve pipe is probably the only remaining component I don't know the purpose for.
You can buy new insides for the praher valves, easy swap out and then you don’t have a lot of replumbing.
Is there a keyword I should use to search? Thanks!
