First Year Rookie
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
32,863
Purchase enough CYA to get to 30 and get it in the pool now. Then, when you start the SLAM, your CYA will be at the correct level - 30 ppm.
Reactions: Wobblerlorri
Hottsies5
14
Smithton, il
Ok just wanted to check in and post my current numbers.
FC - 2
CC - 1
TC - 3
TA - 40
CYA - 50
PH - 7.0
CH -75
Any suggestions?
Pool looks awesome!
any ideas on keeping my White Vinyl Steps clean?
Seems to always get a yellowish ring around the water level, especially after a lot of swimmers
Thanks!
Richard320
22,069
San Dimas, CA (LA County)
FC - 2
CC - 1
TC - 3
TA - 40
CYA - 50
PH - 7.0
CH -75
Any suggestions?
Pool looks awesome!
Thanks!
Did you complete the SLAM? 1 CC says you didn't.
Yellow ring sounds like pollen.
mknauss
22,735
Laughlin, NV
There they are. You might want to go into your Setup and untrack CSI -- not really applicable to a liner pool.
The 1 CC is problematic. Raise your FC to 20% of CYA for a couple days and see if that clears up. Also start testing every day and adding liquid chlorine. You need to be sure your FC stays well above the minimum.
