Hello new friends at TFP! We are new to pool ownership after purchasing a home in Southern NH last Fall with an existing above ground, salt water, pool. I am trying to learn all about pool care and maintenance and the resources here have already been great! We had our local pool store help "open" our pool last week 4/15 and they are returning tomorrow to check and balance it. Today I dropped off a water sample for testing at the store, but am planning on ordering an at home test kit based on the group recommendations here. I want to start following the recommendations from TFP, but fear that tomorrow the pool people will come with their own sets of recommendations and chemicals to purchase. I can tell just by reading the "recommended range" on the report they emailed me, that our goals here are different than their recommendations.
Our pool is approximately 14,000 gallons, above ground, uncovered, and in full sun. Due to the temperatures in NH, we won't be able to rely on our salt cell to generate chlorine for quite some time (until water temps get above 52 degrees consistently). So, right now, I think we will need to add:
salt?
cyanuric acid?
ideally borates?
what to do about cholorine until salt cell can be turned on to generate?
Since we are new to this, I want to make sure we do things correctly and in the proper order. Can anyone take a peak at the results and walk me thru the steps of what we should address first. Thank you in advance! Willing to read and learn as we go. Just want to have some knowledge before they dump stuff in the pool tomorrow that we might not want or need.
Appreciate the time to help us!
- Newbies in NH
salt?
cyanuric acid?
ideally borates?
- Newbies in NH
