- Apr 19, 2022
- 22
- Plaster
- Pentair Intellichlor IC-40
Hello everyone, newbie here... I just took the first water test and have the following results:
FC: 2.0
pH: 8.2
TA: 170
CH: 325
CYA: 20
Salt: 3400
CSI: 0.79
Seems like I need to focus on lowering pH and TA, and raising CYA, and then everything else will stabilize a little better?
I started with pH... PoolMath said to add "1 quart, 2 oz. by volume" of the 31.45% muriatic acid. That doesn't sound like much for a 15k gallon pool... so what does "by volume" mean? I already entered my pool capacity in Settings, so the 1 quart, 2 oz must be the final number right? I put it in and did a pH test a couple of hours later and it was still 8.2... did I not wait long enough?
As far as TA goes, I'm running the waterfall along with the spa spillover to aerate the water and lower it... am I on the right track with this?
Thanks in advance!
FC: 2.0
pH: 8.2
TA: 170
CH: 325
CYA: 20
Salt: 3400
CSI: 0.79
Thanks in advance!
