I say "pool" owners, because it is an inflatable AG. But we figured it was a decent place to start & make sure we know what we are doing before stepping up to a larger pool down the road.
We set it up once and as it neared full, we realized it wasn't in a good, level spot and was cockeyed, so we chose to drain it and move it. It still isn't perfect, but it will work for now, while I work on preparing a new spot and leveling that area before moving it again.
It was all filled as of about 6 hours ago. I used the PoolMath app & added 5.3 oz of CYA (Clorox Stabilizer) via the sock method & 6 oz + 1tsp of bleach. And the pump has been running since.
I didn't write down my test results I ran on the water before adding anything. But here is the test results 6 hours after adding everything.
Sorry, I am having to resort to using Clorox Smart test strips, while waiting for the 2006C test kit I ordered to arrive. I know these aren't ideal, but I figured they were cheap enough to give me a start.
Thank you in advance for any help you may be able to provide.
