Hi All. I am so happy that I found this site as I will be having my first pool installed in about a month. Thanks for all of the great info and forum conversations. I read through the Pool School sections and am a bit overwhelmed about the chemicals and testing. Most of that is because I am color blind and dreading trying to decipher the test result colors...my wife and kids will have to help with that
The pool package comes with a bunch of chemicals and I was hoping someone could help me determine what I can keep (are they actually some of these: Recommended Pool Chemicals) and which ones I should not keep. Here is the list:
Chlorine "Power Gran" 10lbs - I already know that I need to get LC but is this usable to start with or should I avoid it?
Water Conditioner 1.75lb
Total Alkalinity 10lbs
Greenaway 1.75lbs - Its says "Green" so this is a no go according to the video, no Green or Yellow potions
PH Up 10lbs
PH Down 3lbs
Algaecide "Super" - This is most likely a no go as well
Once we get through this question, I also have others around how much LC should I stock up on and what/how much chemicals to add to the newly filled pool.
Thanks in advance for all of your help with this.
PH Up 10lbs
PH Down 3lbs
