First year closing. Feeling confident with everything, except my plan for the skimmer and main drain. I have a combo skimmer: the main drain is a second hole in the skimmer, and not plumbed to the pump.
I am planning on using a Gizzmo, and my main drain hole is the only one that is threaded, so it will have to go into that hole. I think this means I will have a problem trying to create an air lock in this line because it will take to long to get the Gizzmo in place compared to a plug.
So here are the two options I am debating:
1. Simply shove a foam rope down the main drain hole and then screw in the Gizzmo.
2. Poor antifreeze down the main drain hole first, then shove in the foam rope and screw in the Gizzmo.
So, do I need the antifreeze option here? Or do you think I could create an air lock even with a Gizzmo
