First TF-100 Test
Jeff J.
Active member
Aug 6, 2019
33
Staten Island NY
Finally got my kit Friday. These were the numbers.
CL. 1.0
FC. 0.5
CC. 0.5
PH. 7.2
TA. 380
CH. 100
CYA. 20
The TA seemed crazy. I took it the next day, this time wipimg between each drop, and it was 260.
I've been using liquid for a long time, but I switched to dichlor and trichlor to bring TA down and CYA up. The daily OTO test showed CL 3-5, with PH holding. Water is very clear. Seem like a plan?
IceShadow
1,072
Milwaukee, WI
Sure. Just be careful not to let the FC fall that low. 0.5 is too low - you may need to supplement the stabilized chlorine with some liquid to keep the FC at acceptable levels.
Jeff J.
Active member
Aug 6, 2019
33
Staten Island NY
I know! I was busy and neglectful. I was using liquid and having trouble keeping the chlorine in. The strips said the CYA was higher than that. And I got a small algae bloom on the bottom. I brushed it and it hasn't come back.
Jeff J.
Active member
Aug 6, 2019
33
Staten Island NY
If you saw algae, then you should really run through the entire SLAM Process.
Well, I did a SLAM, and after one day, it passed all the tests. Yay!
Yesterday, the TA went down to 160, and the CYA went up to 40. Other numbers held steady (except the FC is now 13 and CC 0) Should I back off on the trichlor and dichlor? I'm probably going to close the pool mid-September. HD has a good deal on chlorine, three bottles of 10% for $11.
mknauss
23,665
Laughlin, NV
Unless you drained over half your pool there is a testing error on your TA and you would need to have added quite a bit of CYA to double that result, so check your testing.
IF your CYA is 40, use liquid chlorine from now on.
Jeff J.
Active member
Aug 6, 2019
33
Staten Island NY
Thanks for the quick response! I think this is the most accurate TA test I've had. I wiped carefully and held the dropper vertical. I'm not sure about the CYA. That is a tough test. I'll run it again.
Jeff J.
Active member
Aug 6, 2019
33
Staten Island NY
Well, here's my numbers from a little while ago.
CL. 16
FC. 15.5
CC. 0.5
PH. 7.2
TA. 150
CH. 100
CYA. 30
I'm more confident in that CYA number, although I couldn't swear that I didn't see the dot. I'm not totally confident in the TA, but I think I'm close. My mom was talking to me, and I'm not sure if I lost count, lol.
