First test tf100
Kathy.pearcy
18
North Charleston, SC
Yeah, I completed 1st test and entered results in pool math. Now I don't know what to do first.
FC 1
Cc1
CH 275
TA either 120 or over 250 (It did not turn red just bright pink. Do I stop when it starts to turn from green to pink?
CYA 100
Should I drain some water out and refill before doing anything else
Msch99
388
Verona, MO
PH?
First I would add some chlorine, maybe use 100 or 110 as cya level.
I would do a diluted cya test to see how much you need to drain to get the cya down. You may want to dump tube back into bottle, shake and do test 3 or 4 times to see if you are consistent reading it. (helps me)
TA Make sure you are dropping slowly and wiping tip of reagent bottle between drops. Mine turns red so need an expert on that.
Msch99
388
Verona, MO
Add your pool information in your signature, similar to mine & others to help out the experts.
Menu/settings/signature
Msch99
388
Verona, MO
Oops, skipped my first post.
PH?
Add chlorine first. Use 110 or so as cya level.
Do a diluted cya test to find out what cya really is. 1/2 pool water and 1/2 tap water. Double the reading. Maybe dump tube back in bottle and read 3 or 4 times to help calibrate yourself or take average. (helps me)
Kathy.pearcy
18
PH?
PH?
I did diluted cya test and came up with 120 each time. I guess I should add bleach first then work on draining to get cya down. The enclosure we have is not temperature controlled, so would it be considered an indoor pool?
Signature looks good!😁
That info will help experts, inside pools are a bit different.
I did the diluded cya test and came up with 120. Should I still add recommended amount of bleach first before draining? And how much should be drained. The pool enclosure is not temperature controlled. Only keeps rain and insects mostly out. Is that considered an indoor pool?
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
32,901
We are spinning wheels here. Let's get some progress.
1. You have an outdoor pool
2. What does your water look like? Is it clear or cloudy? Hazy?
3. Report your pH, please.
Texas Splash
Ideally, I would like to see your CYA closer to around 30-50. For your pool, 30 is ideal .. 50 max since your pool probably gets quite a bt of shade. You have a cartridge filter, so you probably have no way to remove water to "waste" with a multiport valve like someone wiht a sand filter. So that means to change water, you'll need to use a seperate pump or siphon water out. At the same time, you must always be careful about the shell and not lower too much water all at once. Our FG pools need to be stabilized witih the weight of the water. Make sense?
So you may have to do several slow water exchanges or slowly pump water out from the deep end while adding fresh water at the shallow. Not as efficient, but it keeps the shell full. Lowering the CYA is step #1 to being able to manage your water properly.
Texas Splash
Chlorine tabs have been removed and chlorinator turned to 0
Perfect! :goodjob: The CYA will never go up again unless you want it to - on purpose. Save any unused tabs for later. They last a long time in a sealed container. So for now, simply determine the best way to slowly exchange water. Easy CYA math .... changing half of the water lowers the CYA by 50%. So use that as a guideline. You may need to do 2-3 partial water exchanges to ensure the shells stays weighed-down and secure, but that's okay. Once you've done that and know your CYA is back down to 30-50, we can help you balance the water properly. If we suspect an algae is trying to grow from the overloaded CYA and lack of chlorine, we can help you through a SLAM Process later. But the CYA is #1 for now.
