We started filling our pool 6 days ago, and it has rained throughout the week as well as the city water we used to fill it. The electrician is finishing the wiring today, so we haven’t been able to use the equipment at all. The water doesn’t look terrible, but it isn’t clear like it was when we first started filling of course. Here's what the water tests at:
Chlorine: 0
CYA: 0 (I assume this since I haven't added any... I didn't want to waste a test since it is a new fill- but I will if I need to. Newbie here)
TA: 100
PH: 7.5
CH: 275
So, I just want to make sure I do this right! The PoolMath App says I should add:
-10lbs Dry Stabilizer (to get CYA to 40)
-1.5 gallons 10% liquid chlorine (to get FC to 5.0) -- But should I bring it to SLAM level since it hasn't had circulation or chlorine since fill began a week ago?
It says the PH is a bit low, but if I add Borax- it will raise TA... which is already on the high end, so......????
Thanks so much for any advice!
Chlorine: 0
TA: 100
PH: 7.5
CH: 275
