First test results after NB pool fill
ahidnes
12
Chandler, AZ
Fill on Thursday, startup from PB on Saturday. Used the TF kit just now, results are:
FC 0.8
pH 7.9
TA 140
CH 450
CYA 48
Pool startup guy said he added enough chemicals to get us through to our orientation on Friday evening.
Thoughts? Appreciate all the help thus far!
mknauss
22,749
Laughlin, NV
Chlorine will need to be added daily. I suspect lowering the pH will need to be done daily also as the plaster is new.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
32,863
You are already too low on chlorine so your pool guy may have put some pucks in but you sure need to add more chlorine ASAP. You should be up around 4-6 ppm FC.
Report CYA to the nearest 10's. (30, 60, etc.) So your test result for CYA is 50 ppm.
