M MnD Member Aug 17, 2019 8 Lake Elizabeth, CA Aug 21, 2019 #1 FC 1 CC 0.5 CYA 40 PH 7.4 TA 110 CH 90 Help
mknauss Mod Squad TFP Expert Bronze Supporter May 3, 2014 22,434 Laughlin, NV Aug 21, 2019 #2 Add chlorine, now. Follow the FC/CYA Chart
M MnD Member Aug 17, 2019 8 Lake Elizabeth, CA Aug 21, 2019 #3 mknauss said: Add chlorine, now. Follow the FC/CYA Chart Click to expand... Do I follow the SLAM amount?
mknauss Mod Squad TFP Expert Bronze Supporter May 3, 2014 22,434 Laughlin, NV Aug 21, 2019 #4 What does your water look like?
M MnD Member Aug 17, 2019 8 Lake Elizabeth, CA Aug 21, 2019 #5 mknauss said: What does your water look like? Click to expand... Clear!
mknauss Mod Squad TFP Expert Bronze Supporter May 3, 2014 22,434 Laughlin, NV Aug 21, 2019 #6 Then raise it to the upper target range. Test FC daily and add enough liquid chlorine to keep FC above lower target when you test each day. Reactions: MnD
M MnD Member Aug 17, 2019 8 Lake Elizabeth, CA Aug 21, 2019 #7 mknauss said: Then raise it to the upper target range. Test FC daily and add enough liquid chlorine to keep FC above lower target when you test each day. Click to expand... Thanks!
