First readings from Taylor K2006C kit
poolnoobgrandma
221
Seminole, FL
So, fill was one week ago, and PB is handling chemicals for the first month. Then we can add salt and the SWCG will start lifting a lot of the load.
There's a chlorine floater with disks in it.
Our instructions have been to sprinkle a one-pound bag of "Super Zappit" shock into the pool 2 days after the filter start up (did that last Sunday), and add 1/3 gallon of muriatic acid every three days. (Last acid was added on Wednesday night)
Current readings (I didn't do them all)
FC 5.4 ppm
CC 0
Ph 7.0
Base demand test to raise ph to 7.3 - 2 drops
PB rep and pool maintenance guy will be over today. Pool is clear and getting nice and blue. Thoughts?
Thanks in advance!
Mr Bruce
2,438
Greenville, SC
Can you do the entire test please?
FC
CC
pH
TA
CH
CYA
You can use a 10 ml sample for the FC/CC test, and each drop is 0.5 then instead of 0.2
Is this a new pool or resurface?
