First pool fill help with saltwater system
ratherbgolfing
Active member
Apr 1, 2021
28
Pa
I'm in the process of filing my new pool now and trying to figure out the process with the chemicals. So what I gather is to balance out the levels of everything first, them test salt content and add appropriate amount of salt. Then I can turn on SWG. I know I need salt in the water before turning on SWG but can non saltwater still pass through cell when it's shut off to help mix chemicals/salt? I have a Solaxx Reliant SWG
mknauss
44,923
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
There is no harm in circulating low salinity water through the SWCG.
Post your current test results. The only thing that is different for a SWCG is a higher CYA level and salt. You can most likely add the salt now. Do you have a salinity test kit? Please fill out your signature.
