I tested my water with my new Taylor K-2006C. I have a salt pool. I took my time, made sure everything was clean between tests, and was accurate in my testing. As was said earlier by a member, my results would probably be different than the local pool supply store and they were right. Some numbers were right on, others not so much.
Anyway, I'm looking for some feedback here since I'm a newbie having only let my pool service go a couple of weeks ago. The concern that still persists is the high FC. For 6 months, I was running my SWCG at 60% and just only turned the SWG down to 25% During the final two weeks of my pool service, the pool guy dumped generous amounts dry stabilizer in the skimmer basket (without a sock) because he said my CYA was low. Do you think this may be the reason the FC is still so high? Here are today's test numbers:
FC: 9
CC: .5 difference. ( I did the 10ml test instead of the 25. It could be lower. It was one drop).
pH: 7.6
TA: 90
CH: 320
CYA: 80
Salt: 3600
Water Temp: 85
CSI: -0.17
Any recommendations? Do I turn the SWG down to 10-15% and wait it out? Anyother adjustments you see I might do?
I usually have to add a couple of inches of water every couple of weeks. Evaporation and K9 activities. Thanks for your help.
FC: 9
pH: 7.6
TA: 90
CH: 320
CYA: 80
Salt: 3600
Water Temp: 85
CSI: -0.17
