hello. I am very uncertain about the sand in my filter pump. My water is very clear, my chemicals are all in ideal range. I have a Bestway 21' above ground pool. I am having a very tough time keeping what seems to be dead algae from appearing again and again. I have vacuumed to waste and the pool looks immaculate but within 12 hours I seem to have the same sediment on the bottom though not in the amount I had. When I vacuum through the filter it also looks immaculate when I am done but after a bit I see the same sediment reappearing. Is this a sign of compromised sand? I do not see any reentry of this sediment (orangish brown) when I am vacuuming on either setting through the jet. I have held a microfiber bag in front of jet (30 mins) to see if it caught any inkling of this sediment and nothing. I am at a loss why this sediment continues to reappear and compromised sand is one thing as a 2nd year pool owner, I am not sure how to identify. As a note, my psi gauge rarely moves from 5 when pump is running which is the normal level for my pump according to specs of model no. I do notice, however, that my jet loses pressure despite no change in the psi reading.
