Filter Psi Reading, should it show at all times?
Co_Diggs
Active member
Oct 10, 2017
33
Dallas, Texas
Hey guys, new pool owner, just getting my equipment turn on and going for the first time.
Answer might be obviously but I just wanted to double check.
The pump and filter are both on and primped and appear to be working as expected. I have the filter set to rinse and noticed the PSI reading shows movement every 2-3 minutes to about 10-ish and then drops back down to 0
Is it suppose show the psi reading at all times or just at a certain stage or the cycle?
I’m not sure of the right terminology to use so hopefully I’m explaining this correctly
ajw22
19,685
Northern NJ
Why is your MPV set to RINSE? That is used only as part of doing a backwash.
Normal setting for the MPV is FILTER.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,348
Is water splashing and sloshing around in your pump basket? If so, that is the reason for your psi fluctuation.......you are sucking air.
