Question: When my pool pump is running at 1600 RPM and I switch the water return valve from normal pool return outlets (there are 5) to the pressure side pool sweep outlet I see about a 5 PSI increase in the reading on the filter gage . The filter cartridges are cleaned as well as the return screen in the pump outlet. Is this increase normal?
