Film on Vinyl Liner
shein33
10
Pittsburgh, PA
I didn't cover my pool last year (big mistake I won't make again) so I ended up with a mess when I opened on 5/22. I've been SLAMing since and I think I'm juuuust about in the clear. Yesterday, I noticed there's is a film on the vertical walls of my liner. It's no where to be seen on the slants to the deep end or the bottom. It's a bit rough to the touch. If I run my nails on it to scrape some off, it is a bit yellow in color and gritty. It does not come off easily with my brush.
Any idea what this could be? My pool had a nice carpet of algae on nearly the whole thing.
I SLAMed with Great Value Unscented bleach from WalMart, Pool Shock and a few hits of granular Chlorine.
FC - 16 (Recommended SLAM level)
pH - 7.6
TA - 70
CH - 90
CYA - 85
mknauss
37,042
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
First -- if your CYA is 90 (round up), your SLAM level FC is 35 ppm.
If you can get a sample of the material, put a drop of acid or vinegar on it and see if it fizzes.
mknauss
37,042
Laughlin, NV
Fiberglass
It would be advisable to do a sizable drain and refill. With a vinyl liner, you can drain to leaving 12" or so in the shallow end.
When you drain, get a good sample of the material. Dry bleach and some muriatic acid on a couple samples.
mknauss
37,042
Laughlin, NV
Fiberglass
Drain and refill for the CYA.
Still thinking a scale, or a algae/bacteria. Could also be iron. Does your fill water have iron in it?
mknauss
37,042
Laughlin, NV
Fiberglass
That CYA is OK to high for a SWCG but I thought you were in the SLAM Process?
Some pool stores will test for iron. Take a sample of the pool and the fill water. Do not buy anything.
Do you have a water softener, conditioner, etc? Do your plumbing fixtures get stained red, brown, etc?
mknauss
37,042
Laughlin, NV
Fiberglass
You will struggle to complete a SLAM at that level of CYA.
