Fill and start after pebble resurface...
MrAl
16
Ozona, Fl
Hi Guys. I’ve maintained my outdoor 13.5k pebble pool for a while now following TFP with zero issues. Love the methodology. Right now I’m getting into uncharted waters with a pool demo and resurface. Old coating failed and I’m putting in a “Wet Edge” finish. My questions are... after the acid wash and initial hose fill, I was advised to do a metal treatment by the local pool store. Thoughts on that? I’m not on well water, so it’s the normal city supply. So depending on the answer to the metal treatment, do you immediately slam the pool? Or just bring up to normal FC levels? I’ve just never had to start from ground zero before as I’m in Florida and keep the pool open year round. I have other chemicals to balance obviously, including salt and borates to 50. (Using pro team for borates). Would love to get some opinions here. Thanks!
mknauss
37,032
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Take a look through the above and pick which start up guide applies to you. Then follow it. Your plaster company should also provide you with the proper start up guide.
ajw22
24,668
Northern NJ
Pentair Intellichlor IC-60
Follow the most appropriate startup guide for your pool for the first 28 days and then transition to TFP Recommended Levels
