Fiberglass pool - Safety Ledge and Many Stairs
Rebel-Redbird
Active member
Mar 18, 2019
25
Yorkville, IL
We are in the process of getting a Leisure Pools Elegance 23' fiberglass pool installed, and I have been going back and forth on robotic cleaners. Haven't had to clean the pool manually yet, so I'm not even sure if a 7,000 gallon, 12' x 23' would be that time consuming to handle with a hand vac.
The pool itself has a seat ledge, a few steps, and a safety ledge going all the way around, so right away I have concerns about any cleaner that has wall-climbing abilities. If one works well, I can see the benefit of having those steps and walls cleaned regularly. However, I imagine a robotic cleaner only getting some of the stairs, and continuously falling off the wall when it hits that ledge and loses suction.
So then I thought I can manually brush the steps/safety ledge, bringing all junk to the bottom of the pool and run a really basic model that only does floors. There seem to be some inexpensive floor only models out there.
If I could brush, then drop a simple robot in to clean while I move on to test the water or something, I can see the value.
So, figured I'd throw my situation out there and see if there are any recommendations. Is a robot worth it, or should I just clean by hand since it's a smaller pool? Should I totally ignore any robots that climb stairs/walls since it might not work all that well with that safety ledge? Any recommendations on a basic model that only cleans floors?
Thanks!
Jimrahbe
12,017
Bedford, TX
Brett,
I am a highly biased robot kind of guy... But, in your case, I think I would try manual brushing and vacuuming for a while and see what that is like. After a few weeks you will either love it or hate it and it will make the decision that much easier.
No matter what, I would want a cleaner that did the floor and walls..
homegameroom
48
Sunrise,FL
Ditto Jim - try manually vacuuming for a bit before dropping a few Benjamin's on a robot. I had a robot, but vacuuming my small pool is fairly quick and a very "zen" thing for me to do. I enjoy it! :)
AnnInOhio
14
Columbus Ohio
I posted a similar question last year, and I am so happy I went with the robot! It climbs the walls of my fiberglass pool and scrubs the water line. I use a brush on the steps and the tanning ledge, and occasionally around the safety ledge. Personally, any enjoyment I found in vacuuming manually was completed erased by my frustration at coiling the vacuum hose back up and putting it away! I’d rather clean out the robot. I did the manual vacuuming for about a month before making the purchase.
Rebel-Redbird
Active member
Mar 18, 2019
25
Yorkville, IL
Do you mind mentioning which model you went with? If it’ll work with your safety ledge I’m betting it’ll work on mine!
