FC loss after Calcium add
vbertone
0
170
Arnold md.
So I read quite a few threads that have had similar issues with loss of FC to 0 after adding Calcium to raise the hardness. Is it possible. I had FC of 6 this morning and now at 3:30 a fc of 0 and low ph, 7.2. My cya is almost 0 though but could I lose that much fc in a day?
Seems odd
mknauss
52,223
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
You are not adding your test results to your Poolmath app so I cannot see what chemistry parameters you have. The addition of pure calcium chloride will not effect the FC.
vbertone
0
170
Arnold md.
I had no idea others could see that. Just added my results after just testing. The calcium is not 100% pure but is the hardness increase from the pool store. Could not find straight calcium locally before I opened.
mknauss
52,223
Laughlin, NV
Fiberglass
With 0 CYA, the FC half life with sun on the pool surface is about 50 minutes. So you can go from 6ppm FC in the morning to essentially 0 in a few hours.
