FC levels and trichlor
Whatrymes
134
E. Bridgewater, MA
I'm just curious . . . Assuming my pool water has near 0 PPM of CYA, and I chlorinate using trichlor tabs, will that chlorine that is bound with CYA, be stabilized enough to maintain FC levels through a sunny day? I was just wondering, especially when opening a pool, insted of adding CYA I could use trichlor for a while until my CYA reaches the desired numbers.
Thank you
mknauss
22,790
Laughlin, NV
The CYA needs to get to 30 ppm or so in the bulk pool water before it provides protection to the FC from UV.
So no, if you wish to manage your pool using TFP levels, you need to add CYA if your pool water truly has 0 CYA.
