Generally, CC over 0.5ppm indicates there could be a problem with algae. In my case, could it be the solar cover? We have not had the solar cover off the pool for two weeks due to both cool weather and travel. The pool has not been vacuumed during that time either and I can see a good number of leaves on the bottom of the pool. Last week, the FC was 9 ppm so I turned down the SWG from 30% to 25%. Still over 7 days, the FC went up to 12 ppm. Generally, you see falling FC if the CC is rising due to something like algae.
Should I make sure I pull back the solar cover for part of the day for ventilation and allow sunlight to hit the water? Also run the vacuum daily during this time since the organics load from the leaves is higher than would be during the summer.
