FC and CC
SomePoolGuy
4
Fayetteville, Nc
My mind is a bit blown, so I just wanted to double check and just ask.
Per the TFP method, I should keep my FC levels at the right level, per the chart somewhere on this site.
Question 1: If/when my CC levels rise above .5 then there's something going on and I need to SLAM. Otherwise, the CC gets burned off by the sun. Correct? Just trying to confirm 'where the CC goes.'
Question 2: Why does the pool industry tell everybody to shock the pool? Is it just $ ?
Thank you!
Jimrahbe
15,883
Bedford, TX
SPG,,
You should test your CC's and if they go above .5 for a few days in a row, then you can troubleshoot to see what the cause might be.. You only need to do a SLAM if you know or suspect that you have algae.. A couple of days with your CC's over .5 is not a major problem.. It just means you need to keep an eye on your pool balance.
For reference.. I have three saltwater pools that cumulatively have been under the TFP pool care process for about 19 years.. In that time I have never had to SLAM and I have never added even one bag of pool store shock...
If you follow this CYA to FC chart, you will never need to shock your pool... FC/CYA Chart
Reactions: wireform
ajw22
13,208
Northern NJ
FC/CYA Chart
CC's can come from various sources. You need to figure out what the source is before you take action. Read...
You should do a Overnight Chlorine Loss Test to confirm you have an algae problem before the SLAM Process.
YippeeSkippy
12,433
Evans, Georgia
I have a cover on my pool. If I open it up and test soon after I might get a CC reading of 1. Give it a couple of hours sunlight and it may be down to 0.5 or 0. So basically I know its trapped Chloramines under the cover and once I give it a chance to "breath" and let some sun hit it it is going to be fine.
IF it remained higher than 0.5, I'd be looking for a reason. An Overnight Chlorine Loss Test could help me determine what the problem may be:
Its all a matter of understanding what CCs are, and what they may be telling you.
