FC and CC
TamithaSue50
184
Parkersburg, WV
So last night I tested my FC and CC and my CC was .5 and tonight it's 1. I know it's supposed to be .5 but can it be 1 and there not be any problems or does it mean he it's anything over .5 there's a problem?
frogabog
2,833
Portland, Oregon
With 1ppm CC there could be a problem, yes. Your Pool Math logs are hit and miss, it looks like you saw the 1ppm CC 3 days ago as well, but the last test result before that was 21 days ago. Are you falling under your minimum a lot?
You can do an OCLT tonight to see if you lose 1ppm or more which will tell you if you need to SLAM or not.
Jimrahbe
15,405
Bedford, TX
Sue,
I would not worry about a one time reading of 1 ppm.. If you keep getting a reading 1 or higher, then I would take actions to see what is going on..
TamithaSue50
184
Parkersburg, WV
Okay so I checked them both again this morning and they are both still the same so I didn't lose anything over night but the CC is still reading 1 but I guess since I didn't lose any overnight that it's okay right?
Msch99
388
Verona, MO
Tamitha
We have a tree that shades about 1/3 or so, always dropping acorns, leaves, pollen etc. Not unusual for us to have 1 or 1.5 cc, particularly if pool heavy use and uncovered. Much better though since we purchased a robot to do the heavy lifting when cleaning the floor!
TamithaSue50
184
Parkersburg, WV
Tamitha
I have trees around mine too. Sadly only get about 2 hours of sun a day on mine. But next spring I'm hoping to have the money to get them cut down.
