Okay, so another few questions:
1. Do I need to be in attendance while this process is going on?
2. Any idea at all how long this might take? Ballpark idea? I realize it depends on GPM from the sump pump. What about GPM from the fill hose? I usually use 2 fill hoses but it sounds like we want still waters for it to work. The 5 gallon bucket is placed in the shallow end, with the top of it above the water level, with the fill water going into the bucket, so that it sorta oozes over the edge so as to not cause any turbulence, right?
3. I don’t think my sump pump is submersible, is this a problem?
4. How do I know it’s working and I have it set up correctly? I would hate to go hours and gallons just to find out I did it wrong.
5. I called the water authority, we are on conservation status, only no penalty month for pool fills is April. It’s estimated to cost me about $200-$300 to do this.? No rest for the wicked I guess.
6. Does the distance the effluvent water has to travel come into the equation?
6. Any of you experts in ALBUQUERQUE for the holiday and want a side job??
