I had the gunite completed on a new build and on the outside of the pool in the deep end there is a small exposed piece of rebar. Its probably about half an inch at most. There is at least 8 inches of gunite around it going into the pool from measurement I have taken. Does anything need to be done with this?
Should it be cut back sealed and then get an inch of hydraulic cement?
You can see its the small dot in the picture just over the ground water.
