Excessive scale in salt water pool
Sep 10, 2020
5
Chicago, IL
Hello,
I have a salt-water pool. Every summer, beginning around July 4, I notice scale powder begin to collect on one area of the pool floor. The amount of scale gradually increases over the next several months. Toward August, I notice that the chlorinator is so packed with scale that it hardly produces any chlorine. If I acid wash, scale will build up again by the next weekend. Also, at about this time of year, there is scale powder on much of the pool floor.
Any thoughts on what I'm doing wrong here? Any thoughts on what I can do to prevent this in the future?
Thank you in advance.
Sep 10, 2020
5
Chicago, IL
Hi,
Thanks for responding. Here are my numbers:
Combine Chlorine - 0
Free Chlorine - 1.0
PH Level - 8.0
Total Alkalinity - 8.0
Turbidity - 0
Cyanuric Acid Level - 0
Calcium Hardness - 230
Salt - 3800 ppm
I believe the pool maintenance guy added a gallon of Muriatic Acid after taking these numbers. The pool/spa combo is roughly 37,000 gallons.
Thanks again,
cowboycasey
4,324
Fletcher, OK
Hey there, Welcome to TFP :)
That scale is happening because the people taking care of your pool ARE NOT taking care of your pool, they are taking your money and going to the next pool and taking there money...
If you want to take care of your pool so this stops happening we can do that :) You will need to order a test kit, I recommend the TF 100 Test Kits Compared
Once you receive your kit jump in and start doing your tests and post back here.. I bet your levels are all out of wack… but we will get you going...
ABCs of Pool Water Chemistry
How does that sound? (y)
Reactions: mickey4paws
